I put everything back together and it runs.... But now I noticed a clicking sound in my speakers and the engine stutters along with the clicking sound.. when I put it in drive it starts stuttering really bad still with the clicking sound... I checked around and dont see anything wrong. It seems to be something with electrical..
Replaced my PI intake on my 03 and a problem
More than likely, yes. They develop a type of memory and may not connect properly to another plug. Sounds odd but had it happen at the shop. also check to make sure all the fuel injectors are seated properly, sounds like you might be hearing the nijector firing, but the fuel is not going where it is supposed to be going."Owning a 9-second Import is like coming out of the closet.... At first it may be surprising, but in the end, you're still gay!"
www.myspace.com/nascarmechanic
Probably the plug wires arcing making the noise in the speakers, same cause for the misfire. Hmm, doesn't a 2003 use coil on plug? There should be no wires if thats the case, but the boots must be in good shape or it will leak spark out to the head and cause stumbling and static in the radio.86 Lincoln Town Car (Galactica).
Check all connections, first.
Next, look for coolant in the plug wells. Use compressed air to blow any out.
Now, I know the 99+ uscar EV6 fuel injector conecotrs are tricky - you may have broken one. Check the injector connector on #1 and #2. If broken, you can use a zip tie to 'rig it'
If that doesn't solve it; next I'd swap the #1 and #2 Cops with 2 other cylinders and chek the boots for cracks.
If the misfire(s) move to the other cylinders, your 2 coils are messed up.
If not check the boots for cracks again, and the plug connecotrs for a solid connection. Replace if needed. Then look into plug issues, etc.Last edited by drock96marquis; 02-10-2007, 04:34 AM.-My Homepage, Panther info & FAQs-
My Mint 96' Mercury Grand Marquis LSE -
Modifications
Click My Merc for more Pics!
Car never had problems with this before..
When I was removing one of the coils, the boot disconnected revealing the coil spring, and leaving the boot connected to the spark plug, I put it back together.
I cleaned all the injectors with alcohol..
I gapped the spark plugs to the recomended gap listed under the hood.
Also.. how do I know where cylinder 1&2 are?
Originally posted by SphinxI just noticed that my pops dident put the spark plug boots back in the numbered order I marked on them.. is this the cause of the stalling?
Once you pull the boots apart like that they are prone to problems.....If you have not replaced them in awhile now is the time to do so....You can get aftermarket hi po boots they are out there.I am not in a place to give you firing order. So if you need it on Mon I can get it...President He Man Woman Haters Club
Life should not be a journey to the grave with the intention of arriving safely in a pretty & well preserved body,But rather skid in broadside,Thourghly used up totaly worn out & loudly proclaiming...WOW WHAT A RIDE!!!
http://www.myspace.com/dabearsplace
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
Originally posted by DatdambearOnce you pull the boots apart like that they are prone to problems.....If you have not replaced them in awhile now is the time to do so....You can get aftermarket hi po boots they are out there.I am not in a place to give you firing order. So if you need it on Mon I can get it...
And I'm pretty sure the cylinders are numbered the same way as well. 1-4 front to back on the passenger side bank, 5-8 front to back on the driver side bank.
i always replace all 8 boots on coil on plug modular engines whenever i change the spark plugs
