Truly awesome 4.6 tech..
DRILL TO MARAUDER AIRBOX ¿WHERE?
!Wowwww! CHEVYGUY Thanks a lot for post those pics in fact I was calling today to Lonnie at BOC to check the shipping charge to buy the Marauder airbox so I will be alert to the E-mail and soon I will order those airbox, Thanks a lot Mang.
ATT, SNIPER 308.MANG FROM THE DARK SIDE.MERC75-INTERCEPTOR, BORN IN 2003,DIED IN SEP/21/2010 AT 9:55AM AT THE SORT AHE OF 8 YEARS PROTECTING HIS OWNER TO DIE
looks like you took care to make the hole just the right size chevyguy. i did not, i just hacked a hole in there. had to use silicone sealant around the hole.2000 Mercury Grand Marquis LS HPP.
http://www.cardomain.com/ride/2336322
Friends don't let friends drive donk.
I can't take the credit, Turbodiesel installed that back in 04 before I got the car.
If you look at the old airbox you can see the hole Ford put in there. Just get a hole saw the same size and drill out the hole, then a file to make the notches. Again using the old box hole as a template. IIRC Turbo made a trace then taped this to the MM lid then cut out the notches to match.
If I get popular demand, I will pull the IAT out and shoot a pic of the hole
i was just lazy. i did it all with a knife. :nonono:
maybe i'll take a picture of it later. might give some of you a good laugh.2000 Mercury Grand Marquis LS HPP.
Ok Mangs I found that the the 6 wire harness to connect the Maraudert airbox include instructions in how to cut and joint the harness but I don't know for sure if that is true can somebody tell me i'm undecided now. :confused:
