I am interested in putting sway bars (front and back) on my 2004 grand Marq. I was interested to know if anyone has done this or knows of a company that has these sway bars.
the stock Front bar should be adequate for daily driving, however if you want a larger one, the Police front bar is the best option (29.5mm) it can be identified by the purple dot painted on it. You probably dont have a rear bar, unless you have RAS. the 21mm HPP rear bar should bolt right in.
2003 Town Car Signature - 3.27 RAR, Dual exhaust and J-mod - SOLD 9/2011 89 Crown Victoria LX HPP -- SOLD 9/2010 88 Grand Marquis LS - The Original -- Totaled 5/2006
The 29.5mm bar (CVPI, 95-02) will not work on an 03+
The 04+ CVPI 29mm bar can be used, though
Ford p/n: 4W1Z-5482-DA
If you like more of an oversteer condition (vs factory understeer), you can leave the front bar stock and swap in an HPP 21mm on the rear
Ford p/n: YW7Z-5A772-CA
I suggest running this bar on ENS poly bushings and endlinks.
Complete ENS endlink/bushing kit for rear 21mm: 4.5171R
If your 04 GMQ is an HPP, look into ADDCO bars front and rear for most impact
