Got my springs done
    when i did the front springs on my 85 i just put the car on stands put the jack under the a-arm removed the upper shock bolt removed the upper ball joint, let the pressure out of the jack, and then removed the shocks lower bolts and had to pry the spring out, it was not in compression just kinda trapped in the arm because i did not have the car very high. reinstallation was pretty easy since the spring going in was much shorter (about 4-5")
