I know its inside the door, but where and what part tells me what gears my car came with?
How to tell what gears my car has?
There should be a little tag on your rear end cover.1984 CV tudor 351W, 4bbl, 5-speed best time in the 1/8 8.39 at 80 with 1.80 60ft time.
The door sticker under the AX field has the axle code. GoodSamaritan has the codes in his signature.
Theres also the tag on the axle. The lower set of numbers are what you want.86 Lincoln Town Car (Galactica).
Under axle codes it said x5. Not sure what that is as its not on good sameritans codes? It says 0255 above the bar code thing, beside the weight and all that .. but no hints to what it is? Like to find out, because a buddy of mine is selling a 3.27 setup and if my car doesnt have 3.27's now, its getting them.79 Grand Marquis
Originally posted by Leafsrule16 View PostUnder axle codes it said x5. Not sure what that is as its not on good sameritans codes? It says 0255 above the bar code thing, beside the weight and all that .. but no hints to what it is? Like to find out, because a buddy of mine is selling a 3.27 setup and if my car doesnt have 3.27's now, its getting them.sigpic
Did I hear my name mentioned?
Btw, the codes in my sig, don't work for the later 90's +Owner of the only known 5 speed box wagon with a lift kit.
Axle codes
Open/Lock/Ratio #
G / H / 2.26
B / C / 2.47
8 / M / 2.73
7 / - / 3.07
Y / Z / 3.08
4 / D / 3.42
F / R / 3.45
5 / E / 3.27
6 / W / 3.73
2 / K / 3.55
A / - / 3.63
J / - / 3.85
I have the same axle in both the 88 mgm and 93 vic and they both have the same axle code.
Not sure what year they changed, but the newer ones are 2digit iirc.Owner of the only known 5 speed box wagon with a lift kit.
Axle codes
Open/Lock/Ratio #
G / H / 2.26
B / C / 2.47
8 / M / 2.73
7 / - / 3.07
Y / Z / 3.08
4 / D / 3.42
F / R / 3.45
5 / E / 3.27
6 / W / 3.73
2 / K / 3.55
A / - / 3.63
J / - / 3.85
