A little background info here, it's a '96 Vic with about 150,000 km (93,000 miles) on it. I'm the fifth owner and have no idea what type of maintenance has been done to it until I got it. It did sit for about six years before I bought it and I don't think that helped things.
Anyways I'm not expecting this car to get great mileage, but 13 mpg seems rather low. I will admit this is almost all city driving with a bit of idling to warm the car up and I haven't been that easy on the gas pedal. The car has also seemed rather sluggish at times and hesitates to downshift as well.
Now I did replace the passenger side catalytic converters just over two weeks ago since one was rusted out. I know one of the O2 sensors was damaged while removing it and I have had a check engine light since then. I was planing on just replacing the damaged one but I've read replacing both of the front sensors can improve mileage.
This would be the correct sensor right? Also are all four sensors the same?
I also plan to clean the mass airflow sensor and change the fuel filter which I'm hoping will help. I inflated the tires to 35 psi since they were down to around 25, I hope that helps as well.
Anyways if you've got any other tips or suggestions they would be greatly appreciated. I like the car, but at the same time it's only a beater and since the body is starting to rot out I'm only planing to keep it until I can afford something better, likely a newer Panther!
