04 GMQ steering issue
    Hello all
    Last year i had an issue with power steering. Replaced pump, everything was good for a while. Then some time later i started getting "hard spots" while turning. Wheel is hard to turn in certain places. Put in new lower steering arm. That helped a little bit. But recently those "hard spots" seem to be getting much worse. Does this sound like a steering rack problem?
    Any insight is greatly appreciated.
    check the u-joints in the steering shaft. they could be going out and binding. If those work smoothly, then it could be the rack.
      They were good when i put it in, but i'll pop it out and check. Thank you
        don't forget about the one actually in the steering column at the tilt location.
          I checked this out when my 03 bound up. It was the lower shaft, but a few folks online rec'd replacing the intermediate and the bearing at the firewall.
          You might be able to disconnect it at the rack and see if it turns freely.
          Pete
            I believe 03+ are known to have intermediate shaft issues. IIRC there was a recall recently.
            Past Panthers
              05+ recall if you live in rustland:
              Use our VIN lookup tool to check for recalls on your car, or search by make and model. Also, get recall information on car seats, tires and equipment.
              03+ steering column (rack is just below the pic):
              Pete
