I have a '97 Aero HHP w/ rear air suspension. I've been storing it because I have too many vehicles to drive at the moment. I start it every two weeks.
Some time ago, the rear air suspension deflated and will not re-inflate. The dashboard has a message that says "check rear air suspension"
I have a manual but all it says about the rear air suspension is that servicing or repairing it is beyond the capabilities of the average mechanic, and that it should be taken to a dealership for servicing.
I don't have any experience with this type of suspension. I have checked the fuse and relay and they are good.
What would be some things to check? I was thinking that I should check to see whether the air compressor is getting power, but I can't even locate the compressor. Where is it?
My mechanic also could not figure out what was wrong with the air suspension when I had the car in the shop recently to have the fuel pump replaced.
He suggested replacing the air bags with steel coil springs.
I have an '89 box with heavy duty suspension (it has the towing and handling packages), that I'm thinking of scrapping because it's high mileage and the water pump just went out for the 4th time in 8 years.
Are the rear springs from the '89 interchangeable with the '97? What is involved in changing out the springs? Thanks for any help/advice you can provide.
