Slip yoke splines need no grease, they will flood with transmission fluid quickly enough after you fire up the engine.
Yes do use some grease on the seal between the two lips, really doesn't matter what kind it is as it's there just to make things slippery and all grease dissolves into transmission fluid eventually anyways.
