Hello, i'm new here and i own a Mercury Grand Marquis LS HPP 1995
It has 141000 km on the odo.
Well my problem, when the car is at idle i should have full assist, but that is not the case. No codes.
Powersteering fluid is changed.
When the EVO sensor is not working i should have full assist.
So could it be the VSSensor?
But if this sensor is the same that the PCM uses to determine shift schedule than the sensor is working.
When i'm driving above the 8-10 miles steering is a little lighter.
Below it's heavier.
Engine RPM is 590-610 in DRIVE (HOT) and in Park 790-810 (HOT) AC OFF.
So who can help me out here?
Below it's heavier.
