Suggested rear end gears for a 99 police intceptor.
    i just brought a 1999 Crown vic police package. Wanting to know what kind of gears to put in the rear 3.55 or 373. I have the 80mm maf from a ford lighting truck for my cold air intake from my friends marauder. Also adding the sct tune as well.
    3.55s should wake it up and still keep it reasonable on mileage.
      I thought PI's came with 3.55 gears?
      -Matt
      1968 Fairlane 500 - 1998 Camaro Z/28
        The 3.55s that ima get are from an 03 Marauder. So they would be better then the 3.73s.
          Nope 3.27
            Only '00 and '01 PI's came with 3.55 gears. Though it is now an option on the new ones.
            If you go with 3.55's you should be alright with your existing driveshaft, though you will experience vibration at high speeds. If you go to 3.73's you will definitely need the MMC driveshaft to stop the vibrating.
            2000 Mercury Grand Marquis LS HPP.
            http://www.cardomain.com/ride/2336322
            Friends don't let friends drive donk.
              Oh ok i think ill go with the 3.55 thens. That drive shaft is 500 to rich 4 my blood.
                Since you have a 99, you might want to check it first.
                I'm not sure if any 3.27 PI's had the MMC driveshaft, but it is worth looking at it. Here's some info...
                  Nah, 4.10's all the way...:evil:
                    All 1999 Police Interceptors should have a 3.55 RAR.
                    Like mentioned above check the axle tag to be sure.
                    -Michael
                      wow that tag was made on my birthday in 2000 hehe
                        410s are gonna burn 2 much gas.
                          Not necessarily. As long as you don't drive around at 90mph all the time (and living in DC, I know you don't)- then you shouldn't have a problem with gas...
                            Never fear the gear....I am going to 410 as soon as rebuilt....Should be ok unless doing mach 2 on the hwy....
                            President He Man Woman Haters Club
                            Life should not be a journey to the grave with the intention of arriving safely in a pretty & well preserved body,But rather skid in broadside,Thourghly used up totaly worn out & loudly proclaiming...WOW WHAT A RIDE!!!
                            http://www.myspace.com/dabearsplace
                              i'm sticking with my 3.55's. though the mmc driveshaft will be coming after i take care of the plastic intake manifold.
