Hi Grand_Marquis_LSS
I have just thought of another quick check you can do.
If you have no power on the Grey wire at the LCM with the headlights on as in the check above, then disconnect the LCM and check the Orange/White wite for battery voltage, if you have battery voltage then jumper the Orange/White wire to the Grey wire, your headlights should now come on (Hi & Lo beams should work), if they do the the wiring from the LCM through the MFS to the headlights is good, if they do not come on then you have a fault in the wiring through the MFS.
Regards
Dereck
Regards
Dereck
