95 mirror?
    95 mirror?
    I began stripping my 95 and the rearview mirror is much different than the one in my box. It's got wiring attached to it....I cut that and left plenty of slack, and left it marked so I can trace the wiring if need be.
    Mirror has a weird clear button on the top.
    anyway, since it's got wires going to it, it obviously has something my old mirror does not. auto dimming? is that clear thing on top a sensor of some variety?
    anyone with a 92-97 aero wanna go take a look at their mirror?
    Take a pic of it. Most likely an auto-dim unit. I thought that they had a switch on the bottom "off/lo/high" for the sensitivity. The later ones just have an "on/auto" setting.
    Past Panthers
      pics imminent
        actually goddamn facebook upload isnt working
          this is the rear of the mirror
          one shot is the backside of the mirror, the next is the top. i have the little harness that plugs in there.
            It's an autodim mirror. it dims at night when the sensor in the front pics up light from asshole drivers. The sensor in the back tells the mirror whether or not to use the front sensor or not. Put that in your 90. That shit's nice. I added one to my car recently. Mine has a compass.
              cool! thanks bro. i take it that it just needs a hot and a ground? like I said, I still have the little harness that clips into it.
              a compass? damn you! i want a compass.
                er, hot, ground, and ignition 12v probably. 3 wires.
                  Should only really need a keyed power and ground. The third wire you see has something to do with when you put the car into reverse. It brightens the mirror so you can see what the hell you are doing if the mirror is currently dimmed.
                    I've seen autodims that look like that, but I didn't realize Ford ever used them. Most of the ones I've seen with the clear button on the bottom were in Chryslers. They are really all the same anyway made by a company called Gentex.
                    Past Panthers
                      How does a fella decide which wire is which?
                        Tell me the colors.
                          u got an EVTM for a 95?
                          black (betcha it's ground)
                          purple/red or pink stripe
                          black/red or pink stripe
                          the stripes are the same color but I can't quite decide if they're red or pink.
                            No. Give me the day and I will try and help. For sure ground is black though.
                              This should help you out
                              1988 Signature Series Town Car
