i got a '96 grand marquis. has manual a/c, not automatic.. and while a/c is in off position, it still blows out a small amount of cool air.. small amount tho, but it seems the a/c doesnt completely turn off.. any ideas what could be the cause of this and a way to fix it?
vents blow cool air while a/c is in off position
Tags: None
pretty much yea.. while in off position, i can still feel cool air coming from the vents yes. but small amount, if i put my hand a few inches away from the vent i can definitely feel the cool air..
vents open... some air will flow into the system from outside when moving. If it's still blowing a little when not moving... somethings wrong with the AC brain.
yea it happens when not moving, car is completely still and i can even hear the a/c to some extent when it should be off.. now granted, its not like freezing air coming out, its cool air, but in this temp, even a fan could feel like cool air... nonetheless, air is blowing from the vents while in off position and car is stationary
or the vent lever OFF setting isn't actually turning the stuff off (AC Brain).
the blend door lever actuator is a brain of sorts as it controls power to the fan switch as well as all the vacuum to the vents. Just because it's not electronic doesn't mean it's not a brain.
at least that's what it's called in my 88. I don't know if it's the same in a 96... so I used a generic term for the part that controls all the vents and whether the fan switch gets power or not.Last edited by sly; 07-26-2011, 12:49 PM.
Originally posted by slymer View Postthe blend door lever actuator is a brain of sorts as it controls power to the fan switch as well as all the vacuum to the vents. Just because it's not electronic doesn't mean it's not a brain.
umm... duh... I just said a generic term... they don't use generic terms in books. and since I'm not always top of the class with terminology, I use whatever comes to my brain first. Instead of being an ass, why not ask WTF I mean.
remember, I'm not a learned automotive tech... I'm just a gearhead techie that works on his own crap. I don't always know or remember what the hell a part is called.Last edited by sly; 07-26-2011, 07:06 PM.
ok ok, so how would i go about fixing this so my a/c turns off when its supposed to? where is the "a/c brain" or "blend door lever actuator" whatever its called located? and how would i go about determining if that's in fact the issue and then fixing it?
Originally posted by p1n View Postok ok, so how would i go about fixing this so my a/c turns off when its supposed to? where is the "a/c brain" or "blend door lever actuator" whatever its called located? and how would i go about determining if that's in fact the issue and then fixing it?
yeah... find the part with all the vacuum lines plugged into it. It's probably worn out on the part that the vent control lever (Off, Vent, AC, etc) plugs into.
