Hello -- does anyone know if there is any way to "bench test" a digital gauge cluster to see if it works properly? For example, let's say you have a digital dash car and you find the same year model car at the junk yard with a digital dash and you think it might be a good idea to get the gauge cluster just in case yours goes out some time in the future.
Is there any way that the digital dash cluster from the junked car can be tested to see if it works other than pulling your cluster out and plugging the other one in? For example, would a dealer be able to test it, or maybe would some sort of car electronics guru be able to test it?
I figure the likely answer is "no" but I might be wrong. Thanks for any help.
