Hi, Do the ball bearigs or nylon plugs go in that triangle space? Ed
Ball bearings or nylon plugs in window motor on 94 Marquis?
yup. in the corners and the metal gear has a smaller triangle shape that fits inside that.
I just did those in one motor, replaced a dead motor(dissected it later and the plugs were pulverized). I'm wondering if I should just go ahead and do the only untouched door window motor as PM.
Sent from the crapper1989 Country Squire - Twilight Blue, 347 stroker
when I did one on my cars... I did them all... but I used ball bearings so I wouldn't be back in there... ever. Unless one died of course.
Originally posted by sly View Postwhen I did one on my cars... I did them all... but I used ball bearings so I wouldn't be back in there... ever. Unless one died of course.2003 Town Car Signature - 3.27 RAR, Dual exhaust and J-mod - SOLD 9/2011
Except in Texas where they fucking melt in the summer heat and deform and you have to replace them every year in the dead of summer in the frying heat. I'll take cracked plastic gears if it means I can delay the repair until cooler weather.
Replace with some round solid steel bar cut to the same size as the nylon plugs. No more fucking around with them after that. Just make sure you grease adequately. Also, don't get your arm/head/other body part stuck with the window going up because it ain't gonna stop! The nylon plugs were used as a safety feature and meant to sheer with enough resistance.Last edited by LithiumCobalt; 06-18-2014, 10:25 AM.Nick
Past: 1967 Continental convertible, 1987 TC Cartier, 1996 TC DAE & Signature, 2002 LS V8, 2006 Zephyr, 2010 MKZ AWD, and many more.....
Current: 2010 F-150 Platinum Supercrew 4x4
Wanted: 1967 or 1969 Contnential sedan
Only in my dreams: A Continental Mark II
Originally posted by LithiumCobalt View PostReplace with some round solid steel bar cut to the same size as the nylon plugs. No more fucking around with them after that. Just make sure you grease adequately. Also, don't get your arm/head/other body part stuck with the window going up because it ain't gonna stop! The nylon plugs were used as a safety feature and meant to sheer with enough resistance.
I wish we could source 7/16dia x 7/16 long aluminum rod... but I have yet to find a source for that.
might have just found something that would work...
Bearings Online, shopping by VXB ball bearings the online bearing store and supplier, wholesale prices and same day shipping, next day air shipping available. The Ball Bearing Supplier & Distributor
and they're 77¢ each... so pretty light on the wallet for a set of 12 per car compared to the POS bushings that are supposed to go in there.
