Speedo stoppo
This topic is closed.
    Speedo stoppo
    Hello I own a 2000 Mercury Grand Marquis with analog gauges speedometer odometer stopped working other gate his in the cluster work I replaced the vehicle speed sensor on the transmission and still no speedometer or odometer I checked all the fuses at the battery charger box all fuses are good dusty cruise control still works any ideas would be much appreciated thank you
    we'll keep this in the original thread you started. Just hang on, I'm going to post the wiring diagrams for your car. You've probably got a loose wire somewhere along the line from the VSS to the PCM or instrument cluster.
