03 Towncar how to take out map light bulbs?
    So as some of you know, I have a huge LED addiction and im starting to replace the interior lights to LED, Ive gotten to the rear map lights above the rear doors, how do you get the bulbs out? I popped the lens off but theres no way I can get the bulb out of its socket since its so awkwardly placed. Do I have to remove the whole assembly? if so, how do I do that? Thanks!
    2011 Ford Ranger Sport 4.0 2wd - Magnaflow Axleback exhaust, K&N 63 Series CAI, DiabloSport 87 Octane tune, LEDs, 3000K LED projector fogs, 5000K Mini H1 projectors - Daily
    1967 Ford Galaxie 500 Sedan "C-Code" - 289 2bbl/Cruise-O-Matic - Money pit/project
    With the handles? Or do you mean the map lights in the middle?
      The ones with the handles built in.
        The easiest to work on would be pulling the handle down, there should be 2-3 torx head screws holding it to the roof.
          Awesome, thanks!
