Anyone have a connector pinout for the 2008 DDM? I have access to 2007 info, but need pinout for the 2008 for verification purposes, and check into some other alleged 2008 changes.
May I have some technical help please? I have a 2008 P71 with factory remote keyless entry (w/o pad). The trunk button on my remote fob will NOT open the trunk. The button in the center of the dash will. So I know that the trunk latch is not the problem. When I hit the button on the f…
I then found this, which I haven't deciphered enough to determine how useful it would be:
