Interchangeable bodys
    From what years can the Crown Victoria and Grand Marquis be interchanged? I like the 1995-1997 Vic rear lights. Can maybe a Marauder front end be put on it?
    Town Coupe [X]
    Mark VI [ ]
    Grand Marquis Coupe [ ]
    Crown Victoria Coupe
    95-97 Crown vics are nothing like an 03-04 grand marquis or a marauder. Only the 02 and up will be able to interchange some body parts, not sure if crown vics will also be able to use the marauder front but probably
    79 Grand Marquis
      I think the front will interchange, but you'll need the fenders and hood as well.
      I think the real interchange years are 79-87, 88-91, 92-97, 98-02, 03+ for body panels... and the rears only really count after 98 between vic and grand marquis. Before that, you gotta stay within the particular model for the most part.
      there is a thread around here that has this info... but hell if I can find it.
        Read this thread:
        '79 Continental Town Car
        '90 Crown Victoria LTD
        '94 Crown Victoria
          Originally posted by 79lincolnlover View Post
          That clears everything up
          Thanks
          Town Coupe [X]
          Mark VI [ ]
            Not to thread jack, but what headliners fit with what? I'd have to assume almost anything will fit. What will fit a 98 GM?
            1998 Mercury Grand Marquis 131k~ true duals, 2nd cat removed, H-pipe, Xcelerator Turbo mufflers, PI Manifold, 180* Tstat, K&N drop-in.
            1985 VW Vanagon 70k~
