I've been putting regular unleaded, but try to at least find top tier fuel stations instead of off-brand. Does this engine need more octane?
Do we need premium fuel?
Not sure what year or engine you're working with, but I don't believe any of these cars (except maybe the Marauder) need premium fuel in stock form.86 Lincoln Town Car (Galactica).
I used to avoid gas with ethanol, but now use name brand gas like Shell and Texaco. I get discounts at the Shell with my Winn Dixie card. My 86 runs fine on low octane even with advaned timing. Not too advanced or it starts to pings.
I'd rather be a failure at something I love than a success at something I hate.
George Burns
Our cars stock don't have a hot enough spark for the higher octane nor the compression so essentially anything over mid grade is a waste.. But if you like running premium go for it! I do agree sticking to the name brands.. And ugh! Ethanol.. If you have the means to avoid do so
08 Lincoln Navigator L - 233k
03 Mercury Marauder- 63k
Also ambient temperature makes a difference. My wagon really likes a higher octane rating in the summer, she tells me by pinging.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
Does it ping or knock under hard acceleration, like getting on the highway quick?
If it does not, than regular is fine.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
In Florida during the summer I had to run at least mid grade to avoid pinging. With a 180°t-stat I can run 87 year roundhttp://secondhandracing.com/Home.aspx
The box doesn't always like 87. Pings once in awhile.
Usually run 89 in it to prevent it altogether.1990 MGM: $50 E7 heads, HO cam, Holley SysteMAX lower intake, HO upper intake with an Explorer TB. LSC ECM. Lincoln logs into stock dual exhaust. K&N drop in air filter. Wide ratio AOD, 2400 converter with a 3.08 one tire fire out back. Car is less slow now. Then there's the '92 Beater. Dual 2.25" exhaust with shiny tips. Rumbles nice. Super slow. Burns oil too.
my 88 doesn't care... 87 year round. the 93 used to prefer 89 to 87... but the pi engine doesn't care... 87 year round. The Mark with it's 93 mustang 5.0HO doesn't care either... 87 year round.
