Fuel pressure bleeding off overnight
    On my 91 the fuel pressure seems to completely bleed off if it’s sitting overnight and won’t start again unless I give it a shot of starting fluid. 1 year old precision fuel pump. You guys think it could be the fuel pressure regulator?
    Certainly possible. Have you checked the fuel pressure with a gauge? Would be a good place to start and take it from there. Even though you have a recent fuel pump, they do go bad so that is still a possibility.
      they do not hold indefinitely. I've never had one that held pressure more than a couple of hours. The real question is how fast does it prime up? If it comes up to basically normal pressure during the 2 second pump prime when you first turn the key to 'on', thats not why it doesn't start.
        I have 35 lbs at the test port but it still won’t fire without starting fluid, it purrs like a kitten once you get it started
          In doing my diag I found that it idles at 30lbs with the regulator connected to vacuum and it climbs to 40lbs when I unhook the vacuum and i found lean codes for both banks
            Thats normal pressure
            is your TPS good? If not it won't get fuel when cranking
              Update: the IAC was causing my initial hard to start issue but I could smell gas from the regulator diaphragm so I went ahead and pulled the plenum and did valve cover gaskets at the same time
