So I was thinking again (not good for me obviously), if things play out so that I need a whole new engine to replace my 302, why not a 351...
Only reason I could come up with other than the legality of it is the accessory system and brackets. That led me down a rabbit hole of looking up pics of the box AC brackets
So there's 3 different AC brackets?
- a hen's teeth type of 351 bracket
- and TWO types of 302 brackets?
I found pics of the Brown Blob's accessory system:
http://www.grandmarq.net/vb/forum/te...08#post1111108
And those AC brackets are different from mine. The front piece / tensioner mount and top mount piece for the AC compressor is two separate pieces here, where mine is a single piece of alu.
http://www.grandmarq.net/vb/forum/te...04#post1234704
Anyways, I though of modifying the 302 ac bracket to fit, by all sense it'd just require "relocating" the bolt holes that attach the bottom portion of the bracket to the water pump and block. One might need a new hole drilled and others would most likely be floating in air, needing some extending.
Unless someone is willing to sell and send a 351 ac bracket to Finland on the off chance I buy a 351... Preferably not costing an arm and a leg. I need both arms atleast.
These are just random ramblings, I was just intrigued that there are two versions of the functionally identical bracket, except however the coil mount is done.
