Electric and vacuum unit that works with (as part of) the EGR system. Forgot if it is referred to as the EVR?
5.0 Idle issues
Those are the Thermactor Air Diverter and Thermactor Air Bypass solenoids. I don't remember which is which but they control the smog pump. If there are broken vacuum lines they need to be fixed. Check all of the hard plastic ones, they're usually petrified and fragile by now. They can be replaced with rubber hose in the proper size.
The single solenoid below the twins is the EGR Vacuum Regulator. Thats the one with the green line. Red is manifold vacuum, white and black go to the thermactor valves.86 Lincoln Town Car (Galactica).
- Likes 1
Originally posted by gadget73 View PostThose are the Thermactor Air Diverter and Thermactor Air Bypass solenoids. I don't remember which is which but they control the smog pump. If there are broken vacuum lines they need to be fixed. Check all of the hard plastic ones, they're usually petrified and fragile by now. They can be replaced with rubber hose in the proper size.
Did some reading and from what I’m seeing possibilities are.. TV cable, TPS (out of the question), distributor rotor, spark plugs/wires, PCV screen and grommet, and fuel filter. I’m gonna give a bit more info on this issue by saying that the engine only stalls maybe once every 5-6 mins? So it’s not constant, the shudders seem to be constant though. The shudder only happens when letting go of the throttle, not when accelerating and only in drive it seems. Didn’t shudder when I revved it in park but that could be because the engine isn’t under a load. I already did a smoke test for a possible vacuum leak but I didn’t see anything but after I replaced the MAP hose and fixed up some vacuum lines it ran smoother and better, but would stall less than before.
Originally posted by friskyfrankie View PostIf any of the items you listed haven't been changed "recently", I'd change them except the TV cable. See where you are at then.
Did it disappear? Never seen a GM without a PCV grommet.
If you don't have the grommet that the PCV sits in, it's basically a huge oil leak out the back of the engine since that's where the PCV lives (on the rear of the lower intake manifold) and without the grommet to seal the hole and screen below it, oil tends to slosh and splash out of that hole. Replacement PCV valves come with a plastic adapter for multiple systems, just pull that bit off and use the metal core part.
If you don't have the screen, you need one. That keeps the oil from being sucked into the PCV system as much and will keep from burning as much oil. If you do have the screen, you can clean them and reuse them if they're not crusty. WD40, brake cleaner, favorite solvent degreaser... whatever works for you.
- Likes 1
Dorman does make the screen and I always make sure I have all the parts before pulling the old ones. As previously stated, I'd change all three items and would not suggest running it with missing parts. SLY nailed it!What I Own: 1993 Mercury Grand Marquis GS
- Likes 1
