aluminum diff cover for a 91 marquis?
    its an 8.8, 10 bolt, without posi. i'm just wondering which cars of which years will have an aluminum diff cover that'll fit. I'm gunna polish er up like crazy and clear coat it.
    thanks a ton, andy
    none fit right unless you go pricey aftermarket.
    the 98+ cars IIRC have em. But if you're going to look in a yard.. .stick your head under there and see what you can find.
      any 92+ have em. 92-97 should fit just fine tho.
        clear coating pollished up like crazy wont stick to aluminum for long. That with PPG urathane enamel. Spray bomb stuff uga. PPG will stick to brrushed aluminum.
          I just polish and wax.
            Any 8.8 cover will bolt on just fine. My aluminum one is from a 2005 Mustang.
              thanks, i'll polish it and hit it with some wax, which'll have it looking good for quite some time so thats good. so it looks like any 8.8 will fit then.
              thanks, andy
                Yep, grab one from a newer Vic or something. I grabbed one and used it on the 8.8 that was going in (but never went in due to the IRS swap....) my Capri. Fit is fantastic.
                  Originally posted by GilroyRacing View Post
                  VERY similar to the SVO, MAC and TFS ones.
                    how is a good chrome one? Can't find any aluminum covers on ebay, but will still check out the junkyards. looking for a smooth cover with no fins or anything like that. a new chrome one shouldn't rust to quick will it?
                    thanks, andy
                      Keep it waxed if you get a chrome one.
                        I believe TA make the cover for Ford (SVO)
                          Quite possible.
                            will do, i'll get a nice chrome one, tripple chromed and that, and keep the wax on it. Quite a bit cheeper than aluminum which is a good thing for a 17 year old, lol.
                            thanks
