So attempting to get a prime on the engine using a drill and spinning the oil pump drive shaft. It's a brand new oil pump.
as i hand spun the shaft slowly around counter clockwise i could hear oil squirting into the oil filter and filling itup. yay!
now here is the SOB. as soon as pressure starts to build, it's likethe oil pump driveshaft slips in the pump. it jumps like a hex is slipping on a rounded out bolt. ya know? i can't physically see the bottom of the pump or the bottom of the driveshaft, to do that i'd have to take the pan off, drain all the oil, etc. but as i spin it around it definatly jumps once every turn, and so far no oil pressure yet. i was hesitant to attach the drill and spin it up fast until i tried to figure out WTH the issue with this thing jumping all the time was.
so.. WTH. the way it goes is 3/4 turn good feeling, then JUMP. 3/4 turn good feeling, then JUMP. each time it pops it's just as it starts to build up pressure it feels like.
now to compound the frustration as i removed the socket wrench from the shaft, the shaft lifted out of the pump on the bottom and now i can't figure out how to get it back in. their is no way to really manipulate the driveshaft at all from the top of the motor, you have to have it set into the oil pump from below before assembly yes / no?
SO I'M F-ED. now i gotta drain the oil, pull the pan, put the driveshaft back in. inspect for issues (i suspect i'll find none). then what, put it all together and try again? it's a brand new pump...
SON OF A I WANNA BURN THE F-ER TO THE GROUND. Thoughts / suggestions are welcome. Anybody experienced this? should i have just put a drill on the shaft when it was in place and spun it up and seen if this popping / clicking / jumping went away?
