As you all know i have kind of fallen off this website for a while now. A few things have come up and other projects got pushed ahead of the wagon. but most of all i was looking for the best deal for the wagon that fit all my needs. I came across a 302 out of a 76 mach 1, not too long ago. After scrounging parts for a while and passing everything to my machinist i now have the motor near completion.
I stuck with the factory bottom end on the 302 and chose to add a mild ford racing cam. the heads are 351W heads with over sized valves and a 5 angle valve job. All new springs and retainers were added. everything was blueprinted and fit to perfection. I chose to go with a edelbrock airgap rpm series intake manifold topped with a holley 650 double pumper carb and a 50hp fogger NOS setup. water pump and oil pump are also all new and all i have left till the motor gets dropped in is the rest of the ignition system and the fuel pump.
i am also waiting till i finish reinforcing the frame and building my front tilt hood hinges.
