Funny, I thought I would be helpful and check my old computer - turns out it just says "3.0 Taurus/Sable Only".
90 5.0 Town Car uses the 5.0 HO firing order?
is what you need for the ECM program code. It should be a 3 or 4 character code seperate from the main part number. GTE is probably the code, but I don't see it on the list. That list is far from complete though. Wouldn't remotely surprise me if you have the correct original ECM in there. If someone just tossed some random engine in there without really knowing what it came from, or understanding that every EFI 302 is not absolutely the same I doubt they'd have researched the ECM and changed it to the correct one to make the motor right.
The 3.0 Taurus thing you'll find on a LOT of ECMs. No idea why, but it seems like someone at the Ford ECM sticker factory just slapped that label on everything they made for a few years. Feel free to ignore it, its pretty much meaningless.86 Lincoln Town Car (Galactica).
Just got back from the junk yard and scored a ecm out of a 88 mark vii. The computer code is DY3 which, from reading this website, should work perfect.
I also seen another 90 lincoln town car and grabbed the fan shroud and coolant overflow since mine are broken.
I also pulled a plug on the motor and the spark plug hole is the same as my car. I don't remember the plug number but I want to say had a 44 under the part number on the plug. I should have grabbed one.
So since it seems that the 90 tc's had heads with ho spark plug holes. I guess now I can only base my assumption that it has a ho 5.0 in it on the fact that it runs way better on the ho firing order.1990 Lincoln Town Car 5.0 H.O.
Random thought - how would a HO engine run with HO firing order but LowPo injection order (assuming the injection harness wasn't rewired)? I'd guess the fuel would tend to condense on its way into the out-of-sync cylinders.2012 Mazda5 Touring | Finally working on the LTD again!
Originally posted by 1987cp View PostRandom thought - how would a HO engine run with HO firing order but LowPo injection order (assuming the injection harness wasn't rewired)? I'd guess the fuel would tend to condense on its way into the out-of-sync cylinders.
http://fordfuelinjection.com/?p=92 explains it better than I can. It also elaborates on why re-pinning the harness is a bad idea.86 Lincoln Town Car (Galactica).
