what i was trying to get at is you dont need those fittings as long as the original isnt damaged where it connects to the fuel filter......the fitting has barbs on it that will hold high pressure rubber fuel hose.....the hose is around 6 dollars a foot, but it beats 26 bucks for that repair connector
Fuel Line Failure...HELP!!!!
Not that I doubt someone who's done lots of fuel systems, but which factory fitting is it you mean? The ones I'm picturing at the moment are the push-on-the-funky-hose-end-and-lock-it-with-the-plastic-tab sort.
$6-12 > $26!2012 Mazda5 Touring | Finally working on the LTD again!
What exactly did they replace, just a bad section or the whole line? And was that pressure side, return side, or both?86 Lincoln Town Car (Galactica).
Not to be a buzzkill, but don't be too surprised if the return side doesn't hold up all that much longer. Actually its usually the return line that fails first, typically under the A pillar right under the pedals. Save your pennies86 Lincoln Town Car (Galactica).
Originally posted by gadget73 View PostNot to be a buzzkill, but don't be too surprised if the return side doesn't hold up all that much longer. Actually its usually the return line that fails first, typically under the A pillar right under the pedals. Save your pennies
a trained monkey can put compression fittings together......get some 5/16" line and some compression fittings, and do it yourself
