Lately my car has been acting up, I'll be driving down the hwy, and it will jerk. U can hear it in the exhaust, it almost acts like someone just turns a switch off and on really quick. I don't think it has to do with the dura spark box, the distributor, plugs, wires, cap or rotor, mainly because that stuff is all new sense I put on the carb. Could it just be a loose or frayed power wire? It seems to be ok for the first 10-15 min. of run time, than it might act up one every 20 miles, or sometimes its a lot more than that. Its really startin to piss me off though. Any ideas would help a lot. Thanks.
Random miss fire?
Check the connections in the ignition system. Sounds like something loose or dirty. Could also be the ignition switch falling apart if yours is original.86 Lincoln Town Car (Galactica).
Fuel system? A clogged fuel filter or dying fuel pump maybe? It sorta sounds like my symptoms if I run it low on fuel and it starts gulping air in the tank.
Ignition switch on an 86 is the same, and probably also bad. New ones are like 25 bucks, and it may save your car from burning to the ground. Buy a new one.86 Lincoln Town Car (Galactica).
Check the plugs. That carb puts out lots of fuel and it may be fouling them. Sounds like what my 91 does all the time. 9/10 times its a bad plug.1989 Grand Marquis LS
Well its now safe to say its not the ignition switch, or any of the wires under the hood. I installed the ignition switch, drove home, n it still jerked form time to time. So I had it running, and wiggled all the conectors and wires under the hood, and nothin. So I'm going out in a min. to pull some spark plugs and do a compression test.sigpic
All the plugs looked good, but one, the electrode with the porcelain around it was off center. The compression was between 125-132 psi for all 8. But it looked like there was oil under the distributor cap. I put a new cap and rotor on last week, n it looked like crap already, so I cleaned out the distributor,and the cap so I'll see if it runs right on my way to work in the morning.sigpic
If you're getting oil inside the distributor, its probably in desperate need of a rebuild. That might actually be the problem, if its loose enough that oil is getting up there, the rotor shaft is probably wobbling around a bit. COuld be enough to misfire occasionally. That malformed plug also sounds like it should be replaced. May have been made wrong, and it finally failed internally.86 Lincoln Town Car (Galactica).
