started ho conversion
    started out tearing it all down then put explorer cam in then timing chain lifters,pushrods,explorer intake lower and upper i was hauling ass and then as went to prime the motor i knocked over some parts and down something went
    FFF____CCCKKK!!!!!!!!!!!!!!!!!
    my day was over i had to leave so i wouldnt do something stupid.then after an hour i was lifting the motor up and droppng the pan i didnt want to do this so i drop the pan and found what fell a key way from the dorman balancer?and my number 1 cylinder skirt was also in the pan
    somebody looking out for me
    Looks like someone is in the market for a new short block.
    1984 CV tudor 351W, 4bbl, 5-speed best time in the 1/8 8.39 at 80 with 1.80 60ft time.
      That'll buff out.
        that sucks. time for another motor, or at least a new piston.
          that sucks
          what's the plan now?
            say wha?
              I am not a motor man, so what actually happened?
                skirt broke off the bottom of the piston and has been tumbling around inside the bottom end
                  So is the consensus that the motor was fucked even before the swap went underway?
                    That stinks
                      Most likely. Nothing he did was even in the vicinity of the bottom end. That skirt could have broken off years ago and been clunking around ever since. I'm surprised it never made any noises. I'd expect a lot of piston slap without the skirt there.
                        I had two of 'em sitting in the bottom of my pan when I tore down my '89 for the P swap.
                        Time for a new motor. Sucks, but it's part of the game. Good luck on moving forward man.
                          took the head off and the cylinder walls have no gouges or scores its all smooth so im gonna take other head off and see how those are and if it looks good new crank bearings and pistons.
                            took off drivers side head and found no gouges or scores so im gonna get new pistons and rod and crank bearings.its a 87 302 sefi and want to know are these pistons press fitted.
                              Yes, they are pressed, or at least the HO's are.....
