Hi!
I don't have any problems, but I am curious.
To start from the ground up:
Engine timing is regulated by computer? Specifically the ignition module?
It's simply the order in which each of 8 pistons is ignited by the spark plug?
How precise should it be? At an average speed I'm just guessing of 2000rpm, or 33 revolutions each second, the timing should be perfect to 1/100 of a second, or more precise?
Now an error like swapping plug wires will create an instant and significant timing issue. If I ever do that, I hope I notice I've a problem immediately!
But can engine timing become more subtly off...? Is it worth using, from time to time, some electronic diagnostics tool to check the timing order? If it IS off, is there a way to tweak the programming in the ignition module, or, just replace the $40 part?
