I went yesterday and changed the IAC. Car stalls out more now when coming to a stop. Have to keep my foot on the gas when stopping at a light or stop sign to keep the car from stalling on me. Any ideas what I need to change or take a look at next? Also,if I have to turn the steering wheel all the way,like when backing up,car dies too. Going to tune this thing up next. Thanks for the info. John
Car stalling out more after IAC change?
make sure the contacts for the IAC's wires are not mangled and making good contact. Not sure how to test to see if the IAC is actually good or not or whether the signals going to it are good or not though. Check to make sure the gasket is sealed good. A leak there can screw up all kinds of stuff. Also, check any nearby vacuum lines to make sure they're not broken or disconnected.
Also, what car is this?
did you change it or clean it?
is the gasket new? the gasket on our IAC valves looks -almost- symmetrical, very easy to put on the wrong way. like suggested, check your connections for the wiring.
for the hell of it, pull the valve off again to make sure the mating surfaces are good and reinstall it. doesn't take too long and it'll eliminate that as a possibilitysigpic
could be a bad iac......i've gotten quite a few brand new dead iac's....one the other week
Ugh! Did not even think of that. I had a friend of mine put it on. I do not have any tools of my own. He likes doing all of the car stuff. If I could get the stalling issue taken care of,the car runs fantastic. I do still have the old one that I took off.
uh .....try adjusting the throttle screw, i had to adjust mine, my car now idles somewhere in the area of 850 rpm or so, i backed mine off then turned it up just a a notch. coudl be the issuem but i wouldnt mess with the scew unless you know what your doing though.89 townie, mild exhuast up grades, soon to have loud ass stereo....
Ok, just went out there and took a look at the iac. Gasket is not lined up right, this is most likely the problem,right? The bottom bolt is such a pain in the ass to get at. What can I do to make sure that the gasket does not move when putting this back on?
thread the bolts through the IAC and put the gasket on the IAC over the bolts and then put the whole works on the throttle body. The bolts will keep the gasket from doing any weird moving.
