Did 351 equipped cop cars had e7 heads?
Police 351 cylinder heads?
“Cars are the only thing on earth that will beat you, break you, make you bleed, make you cry, spend all your money, spend all your time, not work and not care that you will love more, the more they abuse you.” -AnonymousTags: None
E5AE from 85 onward, probably a D8?? from 79-84. The E5 is very similar to an E7, and neither are impressive. the D8 is also not that different, just manages to be worse than either of the other two in terms of flow and big chamber size.86 Lincoln Town Car (Galactica).
