So I'm pretty sure my timing cover gaskets have failed after 20+ years.
The symptom is oil leaking primarily down the driver's side front of the engine, and it isn't coming from the valve cover or the distributor shaft seal.
I've replaced the water pump before, so my question is pretty simple: How much more time should I figure for taking the timing cover, the crank pulley, and all that crap off? I will also replace the timing set while I'm in there. Does this disturb the oil pan gasket?
Any tips or other info you might think is important is welcomed!
