Suppose this is the right sub forum to post this question in.
Shop told me I need to replace the fuel pump sending unit assembly as well, the old one is crusty and the lines won't budge. It's wasted. RockAuto has just one sending unit, and makes no mention of lock ring size.
So far, my research comes up with three different sizes for the lock ring, 5" inside diameter, 4.625" inside diameter. And Summit shows a 3.5" diameter. That one seems a little small.
Any way to tell which one I need (without crawling under the car) so I can order the proper one? Or even if the Rock one is the right one?
