I noticed while I was installing one of the new shocks that the front of the engine was wet. Checked the oil, it was fine. Checked the radiator reservoir, and it was empty. Mother tells me that if the front of the engine is wet, that's the first sign that the water pump's going out. She says we should be able to do that, so I'm starting to make plans.
AutoZone guide says I need to remove the power steering pump to remove the water pump. Is this true?
This should be pretty much the last thing that goes wrong with the car. Well, maybe the oil pump.
