Car dying, egr filter?
    88 TC 302. Since i got this car it would sometimes die when putting it into reverse. Then restart and back up fine. Lately it has been getting worse. To where i had to give it some gas while changing gears. Then some days it is fine. Today it wouldn't start at all unless i gave it gas, but it idles too rough to want to drive.
    What i have done so far
    New fuel filter
    New plugs/wires/cap/rotor
    Vacuum lines cleaned up, new parking brake switch
    Several tanks of fresh 89 gas
    Battery is up and charging system works
    Air filter clean
    I read somewhere the egr has a small filter than can disintegrate and kill the idle. Supposedly it is under a round plastic cap on the passenger fender. Here is a pic of what i think is that part, with a new filter next to it for reference.
    Is this the right part and how do i remove the cap? It will turn a little back and forth but not pop off. I read not to force or if it breaks the car won't run at all? thanks for any help
    96 MGM
    Cruisin up and down the road...
    have to sneak a small screwdriver under the edge of the cap and then it will pop off.
    To see if this is your problem, unhook the vacuum line to the EGR valve. If no change, its not the filter. Replacing it won't hurt anything though, and I'd shoot some wd40 or whatever down the tube under the filter just to flush out any crap that got down there.
      Thank you. I was able to pop up one side and the little plastic tab was close to breaking so did not remove. i saw what looked like an intact filter so left it alone.
      also unable to disconnect a vacuum line, don't want to break anything. i did remove the electrical connector shown above and it didn't run any better. tried reassembling the connector with dielectric grease, no change.
      any other ideas what this might be? i read somewhere about the iac but do not know what that is and am not having any luck in a search?
      96 MGM
        Idle air control valve, it's on the side of the throttle body, two 8mm headed bolts hold it on. Pop it off and clean it out thoroughly.
          Thanks, that did the trick. I pulled the valve itself apart and also douched out the tb ports best i could. For now it's running pretty good again.
          Mine was stamped 87, i should probably order a new one, it's pretty stained up inside. There is this Motorcraft one on ebay just under 60 bucks.
          Should I stick with oem or try one of the cheap ones from the zone? Job was kind of a bitch and i don't want to have to do it much more. thanks again
          96 MGM
            According to Steve, http://www.grandmarq.net/vb/showthre...l=1#post792464, "Hitachi designed and made the originals for Ford".
            I'm not sure when Hitachi started making the IACs, or if they originally made the ones for boxes (that thread was concerning a '94 Town Car) but I did order a Hitachi replacement for The Scab. https://www.ebay.com/itm/372224374946 That's the one I bought. It arrived a few days ago and certainly looks like the originals that I have seen minus the Ford stamp. I got mine on sale for $30 shipped, but can't seem to find the same ABV0034 on ebay for less than $38 and change shipped, but that's still a fair savings compared to almost $60.
            Edit: Here's another post from Steve mentioning Hitachi being Ford's original supplier which does mention the 5.0 in boxes: http://www.grandmarq.net/vb/showthre...l=1#post805335. Having met Steve, I know his line of work is in parts which is why trust what he's saying when it comes to parts (and more, he's a smart dude).
            Vic
              OEM, or like VicCrownVic said, get the Hitachi unit. I've tried one of the regular parts store IACs and it could not hold a steady idle. It caused it to lope up and down until eventually it got too low and stalled the engine.
              My Cars:
                Looks like the zone has the hitachi for 37 bucks includes gasket. https://www.autozone.com/engine-mana...95340_282446_0
                Will go order one today, need to resupply on brake clean after this job anyway. thanks for the tip! even with tax cheaper than ebay and i get to support a local store.
                Yeah yesterday before i started on this job the car, if it would start, would lope like a Pro-stock or nitro Funny car. Except instead of a big smoky burnout it would just die then not restart. i'm hoping this fixes the problem it was getting to be a major bummer.
                96 MGM
                  Douched...
                  My advice is to hoard a few old originals from the junkyard. I went through two separate motorcraft replacement ones that behaved exactly as the one I tried to replace. Thought it was just how my car was going to be. Then, I went junkin' with VCV and found a minty looking one from an '87 CV along with a minty air cleaner lid with the blue sticker on it... I douched that one out real good, separated the stepper motor from the body of it, lubed it and then slapped it on. No more "voom..voom..voom..correct idle" any more when trying to come down from fast idle after starting. Oh I hated that...
                    ... I douched that one out real good, separated the stepper motor from the body of it, lubed it and then slapped it on. ...
                    uh-oh i did not think to lube it. what did you use for lube, and where?
                    96 MGM
                      I used Lucas chain lube on the motor portion of it, just kinda let a few drops work itself in and hoped as the motor did it's thing it would work itself in even further. For the body portion with the valve thingy I think I used the same stuff, sparingly there too as I didn't want to attract more smut build up. It's been choochin' fantastic ever since. Can't beat the cast in Ford logo either. Another reason the aftermarket one irritated me.
                        honestly I never replace those things unless they aren't working. Pretty sure the one on the Mark VII is the original with near 250k on it. I've never removed it, cleaned it, or honestly done a damn thing with it because it works.
                          I haven't had to dick with the one on our '91 Mark VII either, 158k on it and it's perfect.
                            Yeah i really dig finding original stuff where least expected
                            It if ain't broke don't fix it
                            96 MGM
                              Well just a little followup. We're between blizzards and i wanted to get my annual inspection over with before the next dump, don't want to piss off the mechanic with it dripping slush everywhere. I have 4 good studded tires mounted but my summers are questionable as far as passing. Studs need to be removed end of next month so i want to get the sticker with the good winter tires, then buy myself some time to figure out what to do with all seasons. So i was kind of stressing when it wouldn't run as far as getting it inspected on time.
                              Anyway yesterday i went outside first thing and it fired up and idled smooth. Called the local inspection shop and they got me in for the afternoon. Car purred right into the bay and it passed except for a rear brake line, the easy one. Guy said it was "as clean underneath as you can get for the year." Which is pretty good being a maine car lol. I'm going to let them fix the line next week and i can take my time now, finding some good summer tires.
                              Also i ordered up the 37 buck Hitachi iac from the zone. Like gadget and Derek i prefer original parts, but with the props from Wolf and VCV i feel good about keeping the new one in my spares box just in case mine craps out again. Changing it out is enough of a task for me, without having to spray out the old one again, i don't do well with fumes, headaches etc.
                              Besides the one on the car looks like an old dirty carburetor inside, kinda discolored, kinda rough surfaces, etc. i figure for 37 bucks it's cheap peace of mind even if i never need to use it. thanks again for the help!
                              96 MGM
