My 88 mgm
    KOEO
    11 - passes
    CM (stored, this is what you get after the KOEO)
    18 - IDM circuit failure or SPOUT circuit grounded. - this is usually something fucky with the TFI, connections to the TFI, the pickup, or that other wire coming off the coil. SPOUT is the timing advance system. IDM is the ignition diag monitor, its a resistor connected to the - side of the coil. If you look at the green wire on the coil, one goes to a rubber blob. Thats the IDM connection. If the wiring at the coil is messed up, that can flake out. Also could just be the coil is randomly not sparking because of some problem with the TFI or pickup.
    22 - MAP/BP sensor out of self test range. - either you have no vacuum to the MAP, or the MAP is bad.
    KOER
    21 - ECT out of self test range 0.3 to 3.7 volts. usually means the engine was cold when the test was run. If the engine was warmed up, the coolant temp sensor is bad.
      http://www.grandmarq.net/oldfuelinjection/page14.html
      KOEO
      11 - passes
      KOER
      Think im just going to replace the whole damm distributor. The tfi is new ill go get a replacement again see if that fixes it.
        Got to check or replace the other stuff gadget wrote. A slightly upgraded (hotter) coil is not a bad idea. You can go to platinum plugs that way.
          Which do you peeps recommend? I've had nothing but bad luck with aftermarket coils or caps.
            It does have platinum autolite plugs and it has a new coil form orily it’s blue not sure with one it was. Itsthis one but i think ima get a new one or better one. Probably just get me one of those motorcraft ones just in case
              Same here about 2 months ago I ordered a motorcraft cap and it was complete shit from rockauto. That why I replaced ir with this msd one
                I've had the best luck with the Summit brand brass terminal cap and rotor sets. And it looks like they've stopped rebranding that stuff now. This one looks good though... https://www.summitracing.com/parts/acc-8234
                  So my pedal bezels came in today and it looks really good I like them
                  Still working on the stalling but its been 2 days since it hasn’t stalled so idk.
                    Okay so my next little project that’s been bothering me for the longest is the rear taillights. on my car I smoked them out a little bit when i was going to school I sanded them down then cleared them with clear and a bit of black paint. Then I installed leds so people and police won’t say anything about not seeing them at night or day. Well i liked them a little bit darker but not extremely dark but one of the bulbs is a 921 bulb instead of a 3156 bulb so at night the 921 side looks dimmer compared to the 3156. So I pulled 2 extra 3156 connectors at the jy and i will be attempting to trim the 921 out so that the bigger bulb will fit and all three light could finally be the same shade.
                    Here’s a day pic of how they look not sure if y’all can tell by the pic but the light closes to the reverse are the 921
                      I don't think the system is smart enough to know anything that happens with the cap or plugs. It just watches the output from the pickup and the - side of the coil. If the pickup and coil pulses don't line up like it expects them to, you get faults. Crusty connections at the TFI or the SPOUT connector could also do it if its randomly losing signals to where it needs them.
                      also worth a question, are you using a grey TFI? There are black ones and grey ones. We need grey ones, black ones are controlled differently and will cause you trouble if mixed up.
                      found this, not sure if it will be of any help or not
                        https://www.flickr.com/photos/152575...8/26977950609/
                        Gray motorcraft
                          New or used?
                            Purchased it new but it’s about 4 months old now
                              So its been 3 days and still no stalling. I bought a pillar guage pod from a mustang guy today it came with the guages but ima get new ones. Which do yall think would look better from all of these. I think im leanings towards the old timers white or old timers black. I really want all of them to be the same style and these are the only ones that come in 2 1/16 in a tach so I guess these are my only options. I think the white will closely match the original mgm dash cluster but should I match it or get the black. It will most likely have blue leds also since i have extra bulbs. I will be get 2 more guages for under the ash tray. Ima put tach and voltage on the a pillar and coolant and oil under the ash tray. Which do y’all think need advice.
                                Sounds like a good plan. I'd put the tach and oil pressure gauges up on the a-pillar myself and leave the volts and coolant temp down low. That's the mechanic in me talking though. If oil pressure drops out, you wanna know quick. Kinda why I made the T on the Mad Marquis to keep the idiot light active as well.
