Hello all, the key (and only key) snapped off inside the ignition while in the off position. 1. Can the cylinder still be popped out? 2. Is changing the cylinder a nightmare IE does the whole column need to be disassembled? 3. Rockauto has like seven different cylinders listed, any recommendations, it lists two different Motorcraft styles. And yes I realize ill have to purchase new door lock cylinder as well. Thanks for any tips.
1991 LTD Crown Victoria
