Only way to get effective cleaning of water without choking the flow rate horribly is to have a lot of filter surface area.
heater core restrictor
I what size is the recommended washer hole to use? If you go too small I'm guessing heat output will suffeR?-Phil
Some folks use a cheap socket as a restrictor. So I doubt there's any need to worry about the hole size. As long as there's flow, you will get heat.
Originally posted by WagonMan View PostDoes a restrictor give you more heat? I put a new heater core in my 90 without ATC and I barely get any heat out of it. Even with the 195 degree thermostat. WagonMan
