Originally posted by WagonMan
View Post
heater core restrictor
Some folks use a cheap socket as a restrictor. So I doubt there's any need to worry about the hole size. As long as there's flow, you will get heat.
Leave a comment:
I what size is the recommended washer hole to use? If you go too small I'm guessing heat output will suffeR?
Leave a comment:
Only way to get effective cleaning of water without choking the flow rate horribly is to have a lot of filter surface area.
Leave a comment:
Originally posted by 87gtVIC View PostHe went all "overkill is underrated" on it.
I put a "small diesel" style setup on my cars.
That said, my wife's car was really bad with the chunks and debris in the coolant system and the first filter clogged up in 2 weeks which was just about 50 miles of driving. The next one about 2 months. Then I managed to last until oil changes after that.
Leave a comment:
Originally posted by sly View PostI used the flush T on the heater core input line and just ran hoses from that to the filter (in from engine, out to heater core). I used the following item from Amazon to do it and mounted it on a makeshift bracket I made.
Filter mount:
Filter:
Reader's Rides post:
Wife's car: http://www.grandmarq.net/vb/showthre...l=1#post806998
The cake: http://www.grandmarq.net/vb/showthre...l=1#post811320
Leave a comment:
Filter mount:
Filter:
Leave a comment:
Originally posted by sly View PostI was using the flush T as a restrictor until I put in the coolant filter. That's a good restrictor too.
Leave a comment:
Originally posted by WagonMan View PostDoes a restrictor give you more heat? I put a new heater core in my 90 without ATC and I barely get any heat out of it. Even with the 195 degree thermostat. WagonMan
Were your blend and mode door ok in the hvac box?
Leave a comment:
no, it just makes the core less likely to pop if you wind the engine up a bunch.
Leave a comment:
Leave a comment:
Leave a comment:
