Break Line rusted out, leak, no power breaks
    OK, so my break line sprung a leak since it is rusted out and due to age. The one on the driver side front by the tire and under the floor pan. Local shop says they won't touch it.
    Was going to try a few places that also work on classic cars. What information can I provide to help them? Am I correct in assuming there are universal break lines that are made that need to be bent, cut, etc. of certain sizes? What size is our cars?
    They are 3/16".
    Not sure why a shop wouldn't want to make you a new line. They are fairly easy to make with flaring and bending tools. In a pinch, I have used whatever premade length comes closest to the original, and roll with it.
      You should prob check all your brake lines
      Might be more than 1 that's bad
        Replacing brake lines is a common thing to do. Especially in the rust belt. Best way is replace the whole line. Agree on checking the other lines while you are there. Make sure new brake line fasteners to the frame are used. Lines should not be hanging. Find another shop who isn't afraid of brake lines.
          Reason i said that is because i lost brakes in my exploder 3x in 1 month. Was like brake line russian roulette. Had to replace them all.
            Also you might request that the shop use Copper Nickel lines which are highly rust resistant and very easy to use. If not them then at least a coated steel line.
              There isn't much magic to this, but there is risk of breaking the prop valve if the line is really rusted to it. Driver's side at the A pillar is usually where the rear line usually fails.
                VERY good advice in addition to checking ALL lines along with the brake line hoses at the wheels.
                  replace all the lines. they are 3/16" Use nickel copper line.
                  just ordered a new type of flaring tool that is suposdedly foolproof
                  you will probably have to replace the wheel cylinders and the brake hoses and possibly the calipers if things are rusted and stuck.
                    Let us know how the tool works out.
                      Thats interesting. Guessing you put the line in the block from one side and screw that die in from the other? I've got the kind with the block and the screw press thing and all that. Easy to screw up with that one.
                        I have a hydraulic flaring tool, works the balls. Kinda pricy but worth it to me
                          I bought the Mastercool hydraulic flaring tool a decade ago for my brake lines. Paid for itself after the 1st two brake line jobs. Also bought the 37* flaring die for making -AN hard lines. That tool for me, is a must-have tool.
                            Got my car back. This places specializes in restoring old Datsuns. Anyway, things seem to be working fine. I think they are knowlegeable about older cars which seems to be rare here in California. So far, I'd go back again if I need other services.
                              It is good to find a shop you trust. Perhaps you could consider a shop that works on old mustangs? That would be a closer fit.
