what all would be needed to do a C-4 swap? I know tranny, bell housing, torque converter, fab a new tranny mount. Id most likely buy a Kickdown cable for it. What about flexplate? Will the one for a AOD work?
C-4 swap
C-4 swap
http://www.grandmarq.net/vb/showthread.php?t=5634Tags: None
Most likely you would also need to lengthen or shorten you driveshaft and put a different yoke on it. IIRC SFI approve flexplates arent to much, so if the aod one wont work you could buy one of them. You might also need a new shifter.
You'd need to check into the wiring for back-up lights and such if you plan to have it on the streets.
The shifter you have in there will work on the C-4, you just need to consult with the installation guide to make sure you route the cable properly and use the proper shifter arm on the transmission.
I believe you'd need a C4 flexplate, but I can make some phone calls tomorrow to find out exactly, if no one else verifies one way or the other.2011 Mustang GT Premium, MT82, Kona/Saddle, HIDs, 3.73s, 19s, hood/side stripes, UPR 1.5" springs with adjustable panhard bar, and UMI solid LCAs and relocation brackets.
Your driveshaft should work as well. A c6 has a massive output yoke the c4 does not.1989 Grand Marquis LS
I was told the short-tail AOD was dimensionally the same as a C4, so in theory the driveshaft ought to be the same. Not sure about the mount points but there are two on the frame as Blaze mentioned. Probably just a matter of moving it and changing the mount to the 79-81 type.86 Lincoln Town Car (Galactica).
for a 164-tooth tranny. Is that a common one? Ill most liekly end up buying a tranny from some place like Performance Automatic.http://secondhandracing.com/Home.aspx
Originally posted by DuceAnAHalffor a 164-tooth tranny. Is that a common one? Ill most liekly end up buying a tranny from some place like Performance Automatic.
C-4 swap
I did this swap on the racecar.
Here is a detailed explanation.
I'm debating the manual or a C-4. Basically I am going for reliability first, and a C-4 certainly would. Quesiton I couldn't find in the archives... is it the small or large bellhousing that would fit our cars? Both on TCI's webpage say fit "289-351". Thanks.
The 164 tooth is also known as a 'large bell' where the 157 tooth is known as a 'small bell'.
Be sure and get a 70 or newer C-4 as they have a stronger 26 spline input shaft.Speed cost....how fast u wanna go??
It's not how much hp u have...
It's how much hp u can put to the track...
Let's seperate the men from the boys and put that power to the track using street tires and stock suspension components
'Tis infinately better to sit quietly and be thought a fool,
than to speak and remove all doubt.
I refuse to have a battle of wits with an unarmed person.
What is a good stall to run?
Car weighs about 3500 im guessing
Holley 650 DP on a carb'd 351W that is limited to 6000RPM
3.55 gear, 28" tall drag radials
Not daily driven, but i think i can get away with a rather tame stall since it builds power all through the power band.
Future plans call for a set of Windsor Sr. heads and about a 100-125 shothttp://secondhandracing.com/Home.aspx
Call up Morandon, Just off us-19 in Spring Hill: 727-944-3904
He hooked me up good when Scott was down here workin on the Linc
'80 Town Coupé
I'm no expert, Duce, but from what I've read, 2,500-3,000 should be a good stall for what you're doing.
It won't stall that high when street driving, only when you're linelocking or powerbraking.2011 Mustang GT Premium, MT82, Kona/Saddle, HIDs, 3.73s, 19s, hood/side stripes, UPR 1.5" springs with adjustable panhard bar, and UMI solid LCAs and relocation brackets.
A friend of mine who runs a Mustang shop said he has a big bellhousing for you, if you end up needing it. I didn't get a price from him, but he's very reasonable.
...in case you can't find the right one for some reason.2011 Mustang GT Premium, MT82, Kona/Saddle, HIDs, 3.73s, 19s, hood/side stripes, UPR 1.5" springs with adjustable panhard bar, and UMI solid LCAs and relocation brackets.
