I had a friend's shop pull some codes on my Merc the other day. It was running extremely sluggish, surging after I let go of the acclerator, and I was getting very bad gas mileage (yes OD works fine). So far I had a problem with the EGR Valve stuck open and a bad coolant temperature sensor. I took apart the egr valve and cleaned it out with Carb Cleaner since it was dirty, but I don't know if that will solve the problem.
The main problem is the coolant temperature sensor. It has the original brass one and its stripped badly (can't even get it off with a breaker bar). I know there is a tool set for dealing with stripped bolts, I just don't what it is called or where to find it (tried Sears with no luck). I ran it today without it, my car ran great except for the fact it had trouble idling when driving in a parking lot.
Also, what is the correct size for the vacuum lines that run to the egr. I broke the plastic line for the EGR Valve trying to get the CTS out.
