Originally posted by DuceAnAHalf
That air cleaner was intended for 2V carbs only and was designed for SBC cars using GM HEI distributor.
The Moroso #65926 Would probably do the job for you.
I would have to check which brand I am using on my Capri. If the Moroso soesn't work, this one will. I have never seen it in Jegs or Summit. A local circle track speed shop had it.
