well i have a friend who has them and they need new rockers adn everything. but even if i spend 600 bux on still brand new heads. now can these work with carberatored car b/c i was planing to do the conversion? How much off a gain would i get. I m even thinking of porting and polishing
GT40 heads i have friedn who has them
GT-40 heads will work fine fro a carb motor. I think they say 40hp for GT-40 heads.http://secondhandracing.com/Home.aspx
Matt, I think you mean long block.....like my 1500 buck complete motor. Oil pan to intake, brand new. I wish I had the money to send the heads and intake out and get them worked over.Builder/Owner of Badass Panther Wagons
there are all valves and springs and retainers on it now thats it...still need rods and rockers and vavles need to be reseated and they are stock from a ho 302 86 i belive and i was thinking what should i do to get the most out of them new springs right give me a price range nadi ll probly put new springs and rockers in and send it out for porting polishing and reseating how much woul this cost mesigpic1986 Crown Victoria 302 Cold Air,Mac Shorty headers, Full Dual Exhaust with Super Forty Flows, Wagon Suspension with a Full Sound System Replacement 1/4 time 17.486 @ 77.43mph
Originally posted by mrltdMatt, I think you mean long block.....like my 1500 buck complete motor. Oil pan to intake, brand new. I wish I had the money to send the heads and intake out and get them worked over.
Where'd you get that for $1500??
Just to be shure here GT40s didnt come stock on a 86. Not really a big problem if they are ported air flow is not much different. Need to know what cam you will be running. 800 includes burn and blast, CNC port, our seat and valve work, swirl pollish your valves, proper springs for most cams, valve HT set. Guide replacement, high end springs, retianers, keepers, valves, machined for guide plates. With proper cam intake, exhaust and injectors 400 HP around 6000 RPM is posssibleScars are tatoos of the fearless
Originally posted by jasonhWhere'd you get that for $1500??Builder/Owner of Badass Panther Wagons
so the carb i bought from central 50 will work on this with no prob right and i ll probly get and elbrack performer intakesigpic1986 Crown Victoria 302 Cold Air,Mac Shorty headers, Full Dual Exhaust with Super Forty Flows, Wagon Suspension with a Full Sound System Replacement 1/4 time 17.486 @ 77.43mph
A performer intake only flows around 150 CFM, a RPM or a Air Gap RPM around 170, a Torker around 190, a Vr Jr around 208. Use either the Torker or Victor Jr. with our ported heads and with a cam around 220 duration @.050 and .500 lift for best results in a heavy car. A .450 cam with around 210 duration @ .050 and Torker or RPM, Stock lift a RPM manifold. A 600 to 750 vacuum secondary would work best depending on your cam. You have to match the complete package or you loose power.Scars are tatoos of the fearless
Originally posted by turbo2256bA performer intake only flows around 150 CFM, a RPM or a Air Gap RPM around 170, a Torker around 190, a Vr Jr around 208. Use either the Torker or Victor Jr. with our ported heads and with a cam around 220 duration @.050 and .500 lift for best results in a heavy car. A .450 cam with around 210 duration @ .050 and Torker or RPM, Stock lift a RPM manifold. A 600 to 750 vacuum secondary would work best depending on your cam. You have to match the complete package or you loose power.http://secondhandracing.com/Home.aspx
