So,
I'm thinking (and overthinking) at the lopo 302 rebuild looming in the near future. Next winter to be more exact. (this all under the premise that my block is worth rebuilding)
Basic plan is basic, .30" overbore, H273CP pistons, new bearings and rings, balanced. What else I might need I don't know. Line bore, valve job, deck surfacing. If shit goes south too much, it'll be cheaper to buy another motor.
Currently the engine is stock, except for a Weiand Street warrior intake, Holley 4bbl and HEI ignition. Also the exh. manifolds are staying, for now. I know the exhaust is shit.
My budget being not much, I haven't put much thought into upgrades, except for one, or maybe another one:
- Cam
OR
- Heads
Heads are a simple-ish upgrade I guess, I don't think I'll be splurging for alu heads, just some better iron heads if any come up. From what I've read the E5 heads I have aren't exactly spectacular and as long as I'm not replacing them with heads with bigger combustion chambers or E6SEs, it ought to be an improvement.
I just don't quite like the idea of changing heads due to the many things that need to be addressed along. Finding worthwhile heads to use, CC's, 351/302 head bolts, valve geometry, pushrods, rocker adjustments, PtV clearances.
Whereas I quite like the idea of changing the cam. I have a roller block, so the benefit of a roller cam is a drop-in solution. That would also mean swapping to the HO firing order, which is somehow better I've understood? Free up a little horsepower from the roller setup, along whatever would come from the cam itself. Also not having to do a critical cam break-in sounds great. For budget purposes I wouldn't mind picking a stock replacement cam from a late model 351 or 302, like an explorer or F150 or whatever cam would have the meatiest low-end torque, small budget, aftermarket or not. I have zero interest in high RPM power, I want good driveability and TERK.
Tell me I'm doing the right choices or tell me that I'm an idiot and doing everything wrong, atleast tell me what I should do.
I want an efficient setup, good driveability, torque down low and all done by 4500rpm, which is enough for the AOD (and me).
- Cam
OR
- Heads
