We have an 88 town car stock motor just blew. What would we need to drop in one of those cheap atk carbureted motors? I know the belt and pulley stuff is different no immediate ac...
Turn key crate engines
- Change accessories, oil pan and maybe thermostat housing over to new engine
- TV cable bracket and carb linkage geometry corrector
- Cut fuel lines, install a bypass regulator and hook up carb and return line
- Reinstall oil level, coolant temp and alternator connectors
- Ignition wiring depends on the ignition system. Could maybe reuse original coil pos side
- Rewire fuel pump relay from switched source
OR
- Buy a long block
- Swap all the efi and other stuff onto the new engine and buy a PNP megasquirt ECM and get it tuned. (or flash stock ecm if possible?)
- Enjoy everything as they were before1985 Mercury Grand Marquis LS, "Maisa"
- Likes 1
Or order a rebuilt stock long block and swap in and drive.
why the hell would you want a carb?86 Lincoln Town Car (Galactica).
- Likes 1
Why'd you go with Sniper when the Terminator kits cost about the same and as much work to install? On Holleys site an MPFI Terminator X kit is $1300, I refuse to believe any shop would price the installation at $4500 and beyond. It can easily be done at home!
Since you've got all the Ford SEFI stuff, there's no reason to go for a Sniper setup other than someone else wanting to bullshit you out of your money. Unless you want an inferior type of fuel injection.
The "foxbody" ecm is the same pinout as your car, so installing a megasquirt and tuning it is just like a foxbody. Even in the intercontinental backwater of Finland, I could get a megasquirt tuned in almost any somewhat bigger city.1985 Mercury Grand Marquis LS, "Maisa"
Call scram speed in Decatur Illinois and get a quote from em. I wouldn't lie on this but I've also ran into a lot of just do it yourself on here lol. Il pass it on to him. Just get it out of your local yard lol. I mix up all the companies I thaught terminator was Holley sniper x. Mixed em up. In any case I definitely shoulda never purchased an a9p lol. Il try to learn more about these systems and pinning and things. They quoted me 8 gs. I explained it's the same as a mustang.
Il just tell him to read the forums. Then il be brief and dismissive about key things. Then after his shit fails il go oh yea why didn't you do so and so lol. Il tell him any competent shop should be able to yada yada lol. Give me the name of a shop you trust. I don't care what state it is. I'm not above calling em.
I'm looking to move out of state. You should see the way people treat each other here. They can all claim they are understaffed but weather you are hiring to have a fence built or anything in the auto machanic technician realm the quotes are often blatantly disrespectful. Paying half up front for materials. They all start often months later. I'm telling ya, it's the way things are done here right now
If they say they can’t do it even after you tell them it’s the same as a fox, run. They don’t want to do it so why should you throw your money at them? Why are you running aftermarket efi if you don’t mind me asking? Depending on your combo, a stock LoPo or ho ecu could get you close until you can get it dialed in.
- Likes 1
Mines a bit different from his. Both 88 four doors. Mine is new 306 that hasn't been properly broken in. It was built with a mild custom cam. It had ported explorer intakes but they were cracked. Just put trickflow intakes on. It's had a EFI conversion using a9p. The hard to find shape headers and gt40 p heads with better springs. Drilled 02 sensors. duals. Slightly bigger radiator. Smog delete. Msd box. I think 19 lb injectors which could be an issue and still need to mess with fuel pump more than likely. Thanks for asking.
