the 4bt should fit length-wise, but I wouldn't consider it a wise decision - it can make good power, but that ain't really what Jon is going after, so dumping 4k for something that's gonna give you the same fuel economy as a $900 military diesel is just a waste, methinks
Diesel --> Towncar
I kinda wanted to do the same thing with a Caprice. A 6.2/6.5 is almost identical in size and weight to a 454 BBC. They are about 650-700 lbs. A 4bt cummins is 7-800 lbs and the 7.3 is about 900. The 6.2 is also more fuel efficient than the 7.3, but it does have less power. I'd rather have a 6.9/7.3 in a truck, but a 6.2 would be more than enough for a CV). I've heard of 2wd C10's getting close to 30mpg. You can run a 700r4 (has overdrive and a lower 1st gear).
There's a guy on youtube who has a 6.5TD in a Nova, pretty badass. http://www.youtube.com/watch?v=DLtEXkLO-XE
My ex-nat'l guard M1008 Chevy sounds pretty much like this one, I have some cherrybomb glasspacks.
http://www.youtube.com/watch?v=_l6P08ibv7oLast edited by DriverSideImpact98; 12-15-2008, 01:29 AM.1998 Mercury Grand Marquis 131k~ true duals, 2nd cat removed, H-pipe, Xcelerator Turbo mufflers, PI Manifold, 180* Tstat, K&N drop-in.
1985 VW Vanagon 70k~
I personally love the 6.2. They can be wound up way tighter than they should for a long time without exploding. It is slow, but they are good motors.1989 Grand Marquis LS
Get the manifolds (intake and exhaust) and the turbo from the 6.5 and put then om the 6.2 then crank the DB2 fuel up a bit and you should be doing pretty good on both power and fuel economy. I'm not sure what upgrades the 6.5 has over the 6.2 but if you can you should swap those as well (like we put 7.3 rockers on 6.9 engines). At least that's my plan for a daily driver down the road: late-'70s shortbed stepper with 1-ton running gear, 5-speed, NP205, 4 discs, tweaked RWAL with manual override, small lift and 35s.
Originally posted by smoke'n'rattle View PostGet the manifolds (intake and exhaust) and the turbo from the 6.5 and put then om the 6.2 then crank the DB2 fuel up a bit and you should be doing pretty good on both power and fuel economy. I'm not sure what upgrades the 6.5 has over the 6.2 but if you can you should swap those as well (like we put 7.3 rockers on 6.9 engines). At least that's my plan for a daily driver down the road: late-'70s shortbed stepper with 1-ton running gear, 5-speed, NP205, 4 discs, tweaked RWAL with manual override, small lift and 35s.
Originally posted by Grandpaslincoln View PostA guy just set a land speed record for fastest 6.5. 153 miles per hour. 300 HP. 6.2/6.5's don't suck, it's peoples perception that sucks.
As for the differences between 6.2 and 6.5...I don't think there's much. 6.5 is the same block bored a little, they have different Ex. and In. manifolds and have an electronic injection pump, and injectors. And generally a turbo. I'm not sure about heads, crank, pushrods, etc.1998 Mercury Grand Marquis 131k~ true duals, 2nd cat removed, H-pipe, Xcelerator Turbo mufflers, PI Manifold, 180* Tstat, K&N drop-in.
Ive seen one 6.2 crank fail. May have been the balancer or the fact the guy modded the injection pump and was running it at 5000 rpm in a tow truck loaded or not.1989 Grand Marquis LS
Originally posted by DriverSideImpact98 View PostEveryone thinks the 6.2 is the same thing as the 4.3/5.7 Olds diesel...
Originally posted by Southern_Pride View PostIve seen one 6.2 crank fail. May have been the balancer or the fact the guy modded the injection pump and was running it at 5000 rpm in a tow truck loaded or not.
Originally posted by Grandpaslincoln View PostElectronic injection pump was introduced in 94. Any 6.5 before that was mechanical. 6.5 heads will swap onto the 6.2 with no problems, would have to anyway if running the 6.5 turbo and intake and exhaust manifolds. 6.5 is about 100 lbs heavier than the 6.2 due to the beefing up of the block webbing. 6.5's also have oil squirters to coat the underside of the pistons.1998 Mercury Grand Marquis 131k~ true duals, 2nd cat removed, H-pipe, Xcelerator Turbo mufflers, PI Manifold, 180* Tstat, K&N drop-in.
